A strange noise raise up after a few minutes in my Eclipse
Home Forums Products Rackmount A strange noise raise up after a few minutes in my Eclipse
    • #109388
      I´m having a problem with my unit, suddenly after a few minutes a strange noise like a pink noise or interference raise up, it is very annoying. I´ve check all the cables and I´m pretty sure is the eclipse.
      I did all the troubleshooting, except reinstall the 4.01 again,… any ideas?
      I´m using the 4.01 software in my eclipse.
      All the best.
    • #124102
        Obviously, it could be almost anything. To be sure that it is the Eclipse, see if it happens with the inputs disconnected. Also, see if any of the Eclipse controls affect it in any way. It's probably not a software issue.
        Note that the Eclipse requires ALL pins of any used inputs and outputs to be connected as either signal or ground – they must not be left hanging in the air. You may have a bad connection on one of these – try swapping cables and see if things change.
