Home › Forums › Products › Stompboxes › Active/bypass of presets with Midi ?
- This topic has 4 replies, 3 voices, and was last updated 4 months, 3 weeks ago by
sigitar.
June 13, 2026 at 10:06 am #195768
I use a specific program for several songs and switch between them with my Morningstar MC4 Pro MIDI switcher. Sometimes I want Preset A to be active and Preset B to be inactive. Other times it should be the other way around, and still other times both should be active. I load the program using the corresponding PC number (which works), but I can’t seem to control the active/bypass state of the two presets using CC commands. I’m trying to do this with
A Act/Byp (M)andB Act/Byp (M). But the program always appears in the state it was saved in, not as the CC commands require.What am I doing wrong? Does anyone know a solution?
June 13, 2026 at 10:26 am #195769
Have you got more than one message being sent on each press on the MC4?
I would have 3 messages per press – PC to select the Programme, then 2 x CCs to put the presets into the state you want them to be in. You have set the CC#s for the corresponding actions on the H90?
June 13, 2026 at 11:32 am #195771
A PC command and 1 or 2 CC commands… (of course I set the CCs)
I found this thread in the meantime, which describes the problem. Apparently, it still hasn’t been fixed. 🙁 -
June 13, 2026 at 11:37 am #195772
Hello Sigitar,
This may be due a known issue with simultaneous PC and CC messages being sent at the time. Eventide will be working on a fix for this. We have confirmed that a simultaneous MIDI PC+CC will work correctly on the previous firmware version 1.8.6. If you’d like to downgrade your pedal, please email support@eventide.com and they will help you do that. Another option is saving versions of the program with the presets activated in the necessary states; not optimal but functional. When the fix has been released we’ll communicate it in the forums.
June 13, 2026 at 12:03 pm #195773
Thanks for the explanation.
I’ll use the alternative workaround. Luckily, there’s plenty of storage space available.
