November 16, 2019 at 1:20 pm #115617
Hello
using the H9000 via ADAT with an RME Fireface + Ableton Live 10.x
When running @ 44100 hz, ADAT works fine.
When running @ 88200 or above, audio sent to ADAT 1+2 shows up on all ADAT 1+2 & 3+4 inputs..
ill do further testing but so far, im thinking this issue is within the H9000…
OS. 1.2.1[5]
thanks
November 16, 2019 at 1:24 pm #153219
Your problem may be caused by the fact that ADAT really only works at 48K or below – this is limited by the capability of the optic fibre.
At higher speeds, ADAT can be converted to something known as S-MUX, where each ADAT channel occupies two of the 8 channels. Sounds like what you are seeing.
November 16, 2019 at 10:59 pm #153225
hey.
Well. that may explain it, yes! i was unaware of that sample rate limit for ADAT. thanks!
November 16, 2019 at 2:41 pm #153220
hi nick, does this mean you you guys have added support for ADAT SMUX?
nickrose wrote:Your problem may be caused by the fact that ADAT really only works at 48K or below – this is limited by the capability of the optic fibre.
Alas, I cannot say. I'll talk to the people who know and get back.
