address error (E12)
Home › Forums › Products › Rackmount › address error (E12)
    • #115688
      Hi everyone.
      Does anybody know what this message that I’ve got from my Orville, while working with a routing configuration on it, mean:
      ” address error occured (E12)
      program: 054C30
      data: 0000F1 “
      I’ve got it only once, but I could not find any info about it. Orville behaves normally so far.
      Thanks in advance
    • #153681
        It's probably a hardware issue of some kind. Make sure the unit does not get too hot and that you have good power.
      • #153695
          Hopefully it will not happen again.
          But, it is 20 years old …
        • #153682
          nickrose wrote:
          It’s probably a hardware issue of some kind. Make sure the unit does not get too hot and that you have good power.
          Hi. Thanks for the response. No, it wasn’t overheating issue or lack of power. Plugged into well-grounded surge protector, and only operated about 20 minutes since power-on. It has never happened since though. Strange.
