after reset H8k fw digital meters not working
Home Forums Products Rackmount after reset H8k fw digital meters not working
    • #114429
      I got the memory error message and did a reset with the 8 key as I had no user stored presets yet   but since then I get no readings on my meters when using digital input   the analog inputs show up fine on the meters
      Any ideas?
      I go into the levels area and it all looks set up proprerly      I think
      Any help appreciated
      Thanks! Tim
      Ill double check all my cabling tomorrow when I have time but Im 99 per cent sure it was functioning correctly befroe I did the reset
    • #147482
        The 8 key will return ALL your settings to factory defaults, so may have changed things that you were using for your digital I/O.
