Assigning functions to the Tap Tempo button?
Home › Forums › Products › Stompboxes › Assigning functions to the Tap Tempo button?
    • #112022
      Quick question. Would it be possible in a future upgrade to allow various functions to be reassigned to the tap tempo button? I only have an expression pedal plugged into my H9 and do not plan on using a Y to add an aux switch. I am finally happy with the expression pedal behavior and do not want to disturb that.
      90% of the time I am not using the tap tempo button with my presets.  An example would be using the Rotary algorithm. Instead of using the expression pedal to switch between slow and fast, I prefer the feel of a real Leslie and using the on/off – fast/slow footswitch. I would love to be able to assign the tap tempo button the slow/fast function since I have no plans on using the tap tempo function.
      I could see many other uses if this would be possible.
      Thoughts?
    • #140301
      edwinstar
        Hi! I also think that this would be a big improvement. Right now i have to use a Digitech F3X Footswitch to switch between Fast and Slow when using the Leslie Algo.
        It would be great if in a future update one could assign the Fast/Slow Function to the Tap Tempo Switch.
        Does anyone else agree or is there already a solution?
        • #140448
          I absolutely agree, i am very disappointed this does not exist, it should have been added to the recent update.
      • #140477
        tzvip
          It would spare me buying an aux switch, please make it happen!
