Aux Switch
Home Forums Products Stompboxes Aux Switch
    • #113800
      stari
        Is there a way to assing an aux swtich to always control the mix, for every preset? I would like to be able to click on the Aux, and have the Mix go to 75-100, and when unclicked it would go back down to 40-50%.
        Thanks,
      • #144805
        gkellum
          In H9 Control if you click on Pedal in the bottom menubar and then Aux Switch Mappings, you'll see a pedal function 'Set parameter 1'.  You can use this to have the aux switch toggle the mix value between two settings.
        • #144806
          stari
            Thank you! Now I’m wondering is there a way to use the Aux Switch to increase the mix to 100, but upon another click it would decrease it to the preset’s saved mix level?
            • #144808
              gkellum
                stari wrote:
                Thank you! Now I'm wondering is there a way to use the Aux Switch to increase the mix to 100, but upon another click it would decrease it to the preset's saved mix level?
                Some algorithms have a HotSwitch which allows you to toggle between two sets of preset values.  An aux switch can be used to control that, but not every algorithm has that function.  The HotSwitch could be used to do what you're describing though.  It's available in all of the reverb (Space) algorithms as well as the algorithms that were developed for the H9.
