Aux switch for Restart of H9 Harpeggiator?
Home Forums Products Stompboxes Aux switch for Restart of H9 Harpeggiator?
Viewing 4 reply threads
    • #114146
      aviavi
        Hi. I’m tryin got figure out whether it’s possible to assign an external non-latching footswitch to control the Restart for Harpeggiator patterns.  I have a Boss FS-5U (unlatched/momentary) footswitch. It works when I assign the FS-5U to Tap Tempo in the Aux Switch Mappings. But when I assign the pedal to Performance Switch (which is I think how one might control the Restart), I get a message on the H9 of “All 3 and All 4.”  With some presets, the Length parameter toggles between the range values around the Length knob.
        Any words of wisdom to get Restart happening? Thanks much.
      • #146315
        camn
          I can confirm that my external AUX performance switch restarts the Arp on my h9.
          I have to think this is a setup thing.
          You have 1 aux switch only? And it is set to do one thing only?
          • #146319
            aviavi
              Yes, one thing only. And it’s 1 aux switch.  What kind of aux switch are you using? And do you have it mapped in a particular way?
          • #146321
            aviavi
              Oh! I figured it out:  I had the General Settings>Use Expression Pedal, Aux Switch or Both set to Both. Setting it to Aux Switch only made everything work like a charm.
            • #146322
              camn
                Ha. I have homemade switches :). But its a momentary normally open.
                Lets run through a couple things, find the problem.
                Tell me this- what kind of cable are you using- mono or stereo?
                And then lets confirm your settings:
                Pedal–>general settings–>UseExpPedal/Aux/Both–: Set to AUX.
                Pedal–>AUX Switch Mappings–: confirm your switch is assigned to “Performance Switch”.. and more importantly.. confirm it is NOT set to anything ELSE. I suspect it is ALSO assigned to “Set Parameter 9” (or 10)
                Check those- let us know.
                • #146323
                  aviavi
                    Yup, that was it! Thanks so much for your help.
                • #146325
                  camn
                    Yay.
                    The performance switch is the best thing ever.
