Aux switch mapping
Home Forums Products Stompboxes Aux switch mapping
    • #114438
      jnorris
        Anyone use the aux to control the output volume of an algorithm, like a delay for example? If set to +4, I am honking it can be mapped rom range 96-100 to use as a solo boost. Any assistance is greatly appreciated.
      • #147517
        camn
          As far as I know, nothing…no aux, no midi, can control the output volume on the fly.
          Which, I agree, WOULD be awesome.
          You can control the other parameters, though….so I fake it sometimes.
          Like, in PitchFuzz…the gain knob can add some loudness.
          In a lot of the reverbs/delays…you can start pretty wet, with a lot of output volume…and switch back the mix value to dry-er…which gives you some apparent volume.
          You can add an octave in, or an additional delays/voices… Etc etc.
          Those are what I do.
          Usually with the expression pedal, not an aux switch, though. So much easier, and you can dial it back to get the right stage volume.
