AUX Switch Polarity?
Home › Forums › Products › Stompboxes › AUX Switch Polarity?
Viewing 5 reply threads
    • #106954
      I want to get an aux switch for tap tempo for my TF.
      Do I need a "normally open" or "normally closed" switch?
    • #120147
        It should be a normally open, momentary type.
      • #120148
      • #139883
        peter_heijnen
          I’m about to build an aux switch too. I’d like to use it as a lead boost mostly, make a presets spit out a couple db’s more when engaged. Would that require a ‘normally open’ switch as well?
          I also did a little research on a diy fs300 style switch. I learned that this would require 3 ‘normally closed’ switches. Is that right, and if so what makes the difference?
          Thx in advance!
          Peter.
        • #139920
            All our boxes need normally-open switches. Happily, most push button switches are of this type, including those in the FS300.
          • #139946
            peter_heijnen
              Thx a lot Nick!
              I don’t remember where i read about the normally closed switches, but somebody has put that on the net.
