Home › Forums › Products › Stompboxes › Basic Presets
September 10, 2015 at 4:32 pm #140493
Good idea for a thread, here are the 3 Delay Patches I use quite often that are subtle, they all allow for expression control to increase the delay mix as I adjust that for live performances for various reasons:
September 10, 2015 at 4:53 pm #140494
Spring Reverbs with Trem already on or off depending on the patch, with expression control of the Trem Intensity:
September 11, 2015 at 3:13 pm #112838
Hi guys,
Just want to start by saying thanks for sharing all of these great presets! Much appreciated.
I was wondering if you guys would be interested in sharing some basic “Bread and Butter” presets. Most of what I have tried up to this point are really well put together but a little dramatic for live use. At least for what I do anyways! I currently have an H9 and a Space and would love to try someone elses take on some standard CLEAN RYTHYM and LEAD patches. I have patches that I would be willing to share as wll of course.
September 14, 2015 at 12:07 am #140538
Here are some base presets that I use when I don’t want to lug around one of the racks. They’re close enough to the AD-220 processing, but there’s no way I can replicate the sound of all of those MN3004 chips. The delay time ranges are exact, and the FILTER bandwidths add reasonably accurate limitations. Both DELAYs have duplicated values.
I adjust the FEEDBACK A & B and MOD DEPTH / MOD SPEED to fit the situation. DELAY A & B times are mapped to the expression pedal, and authentically ‘bend in pitch’. WET MIX (“Delay Level” in the AD-220) to taste.
- Effect Type: Delay
- Delay Range 20 ms – 500 ms [@ 700 Hz]
- Delay Range 15 ms – 150 ms [@ 2.5 kHz]
- Delay Range 10 ms – 75 ms [@ 5 kHz]
- Effect Type: Flanger
- Delay Range 1 ms to 22 ms [5 kHz***]
- (1 ms – 13 ms in some inaccuarte vintage advertisements)
*** OK, so I cheated on the 5 kHz. limits. I like to hear the ‘thru-0’ accents on the multiple-waveform flanging in all of their glory.
September 16, 2015 at 4:53 am #140586
Here are a few preset lists in .h9z format with tweaked versions of factory presets and some user forum favorites. I’ll add them to the dropbox as well.
September 16, 2015 at 4:55 am #140587
Basic Presets Tweaked 2
September 16, 2015 at 5:35 pm #140595
Thanks for posting these guys. I haven’t had time to try them out or throw my presets up yet. This evening maybe!
