Behavior when receiving program change
Home › Forums › Products › Stompboxes › Behavior when receiving program change
    • #195478
      pretanovaboss
        I have VST Live sending Program Changes to my H90 and my VE500.
        when I hit play, the VE500 changes automatically. The h90 does not. I have to hit the space bar to pause and then once more to start again and THEN the program change registers.
        If there’s a subsequent change I have stop and restart former the h90 to recognize the program change.
        any insight how i can make it send program change on the first play?
      • #195482
          What is the VST you are using to send PC messages? How are you routing the MIDI to the H90?
          Can you use a MIDI monitor to confirm that it is sending a PC message and the H90 is not changing Programs?
        • #195490
          PhilippeG
            Perhaps you need to add a pause between commands
            I’ve had to do that
