Best Way to Rig My Setup w/ MP-201?
Home Forums Products Stompboxes Best Way to Rig My Setup w/ MP-201?
    • #106473
      So I'm using the Moog MP-201 to control a few analog devices but I'm also trying to use it to control my new Pitchfactor and Modfactor pedals via midi to switch patches and act as an expression pedal.  What's the best way to get the factors to recognize a midi expression pedal?  I couldn't seem to be able to assign a midi CC# to PDL and program expression pedal values that way.  Any advice?
    • #119119
        You should be able to assign it to PDL. Make sure that you have the right MIDI channel (or OMNI).
        Does MIDI LEARN mode work for you with the MP-201 ? If not, it would suggest something wrong with the cables or general MIDI settings.
      • #119121
        Ok great I got this to work pretty well at the moment.  I have
        MP-201 MIDI OUT to Pitchfactor MIDI IN
        Pithfactor MIDI THRU to Modfactor MIDI IN
        This is great except the MP-201 can only transmit midi clock on one channel so I don't know how I can get the Pitchfactor and Modfactors synched now.
