Home › Forums › Products › Stompboxes › Bi-amping with H90
- This topic has 5 replies, 3 voices, and was last updated 3 years, 8 months ago by
brock.
January 20, 2023 at 2:18 am #168544
I’m loving the H90. All the hard work and experience put into this pedal shows, even months after using it daily. I would really love to bi-amp my bass using this pedal. I feel like it would do an amazing job. If there isn’t a way to do this already, could it be submitted as a feature request?
January 20, 2023 at 9:11 am #168545
Love to hear these out-of-the-box applications. I don’t know that there’s a straight-up method for bi-amping, even using Dual Processing. Or using up both slots with the EQ / Compressor. Maybe one or both sides, out the Inserts? Sorry, I’m not in front of the H90, so I could be wrong here. Spit-balling ideas …
My first thought for a workaround would be using Sculpt in Split Mode, with or without minimal Low- and High-Drive. Upsides are setting the crossover point, isolating lows & highs, limited mixing + Low Boost, distortion option, bonus compressor and envelope filters. Downside is that Sculpt will always occupy 1 of the 2 slots.
January 20, 2023 at 9:40 am #168548
Thank you for those suggestions. It would be so awesome if there was a simple program for routing a low frequency range to one output, and a high frequency range to the other output. I feel H90 would do an amazing job at this, but I’m no engineer. Thanks again for your suggestions! I’ll try those out.
January 20, 2023 at 1:23 pm #168550
I wonder if there is another pedal that does this. It’s a pretty easy task in the analog world and seems like a waste of processing power for the H90. If there isn’t another pedal that does just this, there should be.
I think I’ll reach out to some pedal making friends.
January 20, 2023 at 3:53 pm #168553
… It would be so awesome if there was a simple program for routing a low frequency range to one output, and a high frequency range to the other output …
Maybe pad out the THRU Utility algorithm with a Pan & EQ parameter? The EQ slope would have to be steep / parametric. I have found other potential uses for adding a Pan parameter as a feature request there.
But again, you’re using up a valuable A / B Preset slot or two.
The only other pedal I have seen referencing biamping is that Orange Bass Butler. I know very little about it, other than it’s expensive, and big. I guess no bigger than an LS-2 through a stereo EQ would be.
January 20, 2023 at 4:01 pm #168554
Come to think of it, my musings above would be more efficient at the Program level.
