Home › Forums › Products › Stompboxes › Can H9 control Timeline ?
September 11, 2020 at 4:37 pm #116095
Is it possible that H9 will control Timeline? At the moment, H9 sends the tempo to Timeline, but I also want to change my presets, for example … if I change the preset in H9 to no. 5, I want Timeline to change to pr. no 5. How to do it if possible? I note that I know very little about midi. Thanks
Yes, you can just turn on H9's Program Change Transmit in its MIDI setting. The user manual clearly describes how you can set that.
September 11, 2020 at 11:23 pm #155783Some part is already working 🙂 It means that H9 changes pr to Timeline but …. no matter if I go up or down on H9, everything goes up on Timeline
September 11, 2020 at 6:50 pm #155778
Like i wrote….I have read the instructions but do not understand any of it 🙁 Can you help me step by step ? Is there anything I need to set up in Timeline?
https://s3.amazonaws.com/com.eventide.downloads/Product+Manuals/H9-UserGuide.pdf
On page 40, you'll need to turn on this setting:
[PGM.XMT] – MIDI Program Change Transmit Enable (ON, OFF) Press the HOTKNOB button to select. Turn the Knob to set MIDI Program Change transmit ON or OFF. If ON, a MIDI Program change message is transmitted whenever a Footswitch is pressed for Preset load.
Timeline should receive MIDI PC messages by default so I guess it will just work. If not, you may need to ask Strymon or turn on its MIDI PC receive or something.
September 13, 2020 at 2:58 am #155791Thomas.jaw wrote:Some part is already working 🙂 It means that H9 changes pr to Timeline but …. no matter if I go up or down on H9, everything goes up on Timeline
Sounds like Timeline's MIDI PC mapping is not set up correctly.
