Can the Space pedal control the Eclipse via MIDI?
Home › Forums › Products › Stompboxes › Can the Space pedal control the Eclipse via MIDI?
Viewing 3 reply threads
    • #108567
      wilkinsi
        I was watching the Eclipse demo by Alan @ Eventide, during which he used a Timefactor as a MIDI remote to adjust parameters on the Eclipse, without having to set anything up in menus. Is this indigenous to the Timefactor, or can I use the Space to do the same thing?
      • #123266
        achaput
          You can use any Eventide Stompbox to do this. They all have the same MIDI control capabilities!
          -Alan @ Eventide
        • #123293
          wilkinsi
            I just realised you were referring to the EQ in that video. Could the stompboxes control other things in the Eclipse? Presumably, I'd have to assign different CC MIDI numbers for say, the amount of pitch or delay or modulation?
          • #134398
            achaput
              Absolutely. Any effect parameters in Eclipse can be controlled by MIDI CC.
