Change currently active Algorithm on H9
Home Forums Products Stompboxes Change currently active Algorithm on H9
    • #113764
      chemradio
      Hi everybody. Sorry for such a dumb question but,
      I haven’t found a way to change the algorithm from h9 itself.
      I can change presets, I can tweak them as much as I want. But I can’t change the algorithm itself without a computer. Please help me!
      Eventide stated in one of the videos that everything that can be done in h9 control app can be done on the pedal itself.
    • #144642
      gkellum
      If you press the preset switch twice the big black wheel will select algorithms.
    • #144643
      chemradio
      Thank you. will try this when i get to my h9.
      btw. is this method explained in the user manual? haven’t seen that…
      • #144646
        chemradio wrote:
        btw. is this method explained in the user manual? haven't seen that…
        Look under the description of "PRESETS button" on page 8 of the current manual.
        Note that because of the time it takes to print manuals and the rate of development of the software a printed manual may be out of date before you receive it – it's best to download the latest one from the Web Site.
