changing active program via MIDI
Home Forums Products Stompboxes changing active program via MIDI
    • #168875
      darkphader
        I’d like to use a MIDI controller to select and activate programs.
        How would one for example switch to list ‘User 2‘/’Bank 2‘/’Program 05 (2nd one in bank 2)’ then next switch to ‘User 1‘/’Bank 4‘/’Program 12 (3rd one in bank 4)’?
        One would hope that there are PC messages that can be sent but I don’t see any listed in the manual. There are number of CC messages that can be mapped but these only seem to allow relative movement in a list. What am I missing?
      • #168877
        joecozzi
          There is no way to switch lists via MIDI.
          Only way to switch between Programs on different lists is changing to a different Playlist manually within the System Settings or on H90 Control. It’s recommended to organize your Playlist in such a way to access the necessary Programs for your set from the same list.
        • #168878
          darkphader
            OK, just figured out that sending PC messages 1-99 will select a program in the current list. No cliue why this isn’t clearly stated in the documentation. It appears there is no way to select a different list via MIDI.
