Changing presets and sync tempo with 2 H9 and a midi controller
Home Forums Products Stompboxes Changing presets and sync tempo with 2 H9 and a midi controller
Viewing 0 reply threads
    • #112040
      Hi, I am having a hard time to make my midi foot controller to change presets of 2 H9, and at the same time sync tempo and use one expression pedal connected to the master H9 to control both.
      I managed to change presets with the midi output set to through, or to sync tempo and use the expression pedal as desired with the midi output set to xmt. But i can not do both at the same time.
      I am using a Glab GSC-3 as midi controller, which does not have an expression pedal input and, I don't know why, does not send tap tempo precisely.
      Thanks for any help!
