Home › Forums › Products › Stompboxes › Connect Midi Device to Eventide Device – Bluetooth doesnt work
January 5, 2018 at 8:48 pm #114531
iPad Pro 11.xx – H9 Control – H9 MAX
Soundbrenner PULSE – a Bluetooth Metronom.
did this:
go to settings – Connect Midi Device – Midi Device: The Metronom by Soundbrenner
Pedal Settings: MIDI Settings – MIDI Clock – Enable MIDI Input Clock YES. etc.
Soundbrenner Pulse is recognized, but has zero effect/control over MIDI Clock.
no idea why…
any hint would be very appreciated 🙂
January 5, 2018 at 9:19 pm #148042
It's likely that the H9 is ignoring MIDI clock sent that way. Trying to send MIDI clock over Bluetooth will cause problems with your Bluetooth connection to your H9. MIDI clock can generate hundreds of messages a second, which will interfere with the app trying to communicate with the H9. Plus, even if that were not the case, there would be so much jitter added to the MIDI clock sent this way that the tempo value would be unstable and fairly unuseable.
January 5, 2018 at 9:26 pm #148043gkellum wrote:
It’s likely that the H9 is ignoring MIDI clock sent that way. Trying to send MIDI clock over Bluetooth will cause problems with your Bluetooth connection to your H9. MIDI clock can generate hundreds of messages a second, which will interfere with the app trying to communicate with the H9. Plus, even if that were not the case, there would be so much jitter added to the MIDI clock sent this way that the tempo value would be unstable and fairly unuseable.
thank you – so its clear: midi over bluetooth makes no sense 🙂 only midi clock sending wired will make sense, isn’t it?
January 5, 2018 at 9:39 pm #148044gsax wrote:
thank you – so its clear: midi over bluetooth makes no sense 🙂 only midi clock sending wired will make sense, isn't it?
Yes.
