Connecting a Timefactor and HP so Tap Tempo Syncs both.
Home › Forums › Products › Stompboxes › Connecting a Timefactor and HP so Tap Tempo Syncs both.
    • #111232
      Hey all.  How can i set up midi so the tap tempo on the H( will also set the tap tempo on the TF via Midi?  Thanks in advance!
    • #125067
        Connect the MIDI out on the H9 to the MIDI in on the TF. Makes sure the H9 is set from MIDI XMT and CLOCK OUT. Make sure the TF is set for CLOCK in. That's about it.
