Deleting programs from editable lists?
Home › Forums › Products › Stompboxes › Deleting programs from editable lists?
Viewing 3 reply threads
    • #168536
      jay7347
        Is there any simple way of deleting programs that I’ve loaded into a user list? A part B to that question would be is there any chance for “future” program placement swapability within those user lists?
      • #168537
        apalazzolo
          Right-click on a program and select the “delete” option.
        • #168538
            In H90 Control, control+click a Program on your list and there is an option to Delete/Initialize. This will leave an empty space on your user list.
            There are currently no plans for a Program swap on the user lists but I’ll forward your request to the developers.
          • #168539
            jm345
              Is there any way to do this on the H90 directly without using H90 Control?
              • #168546
                  There is no delete option on the pedal itself, you can only save over the Program slot in the list with another Program.
                  If you select a User 2-4 list, these are populated with INIT Programs. You can save one of these INIT Programs to a slot on the User 1 list, and that is effectively the same as deleting that Program from the list using H90 Control.
                  We recommend using H90 Control for Program and list management since it is more straightforward.
