Displayed Midi Numbers on the Factors
Home › Forums › Products › Stompboxes › Displayed Midi Numbers on the Factors
Viewing 4 reply threads
    • #107669
      How do I change the display on the TimeFactor and ModFactor to get Midi numbers and not Bank numbers so I can control it with a pedal board?
      I have seen it where guys have changed the settings in the Eventide units so that bank numbers are not displayed, but midi program numbers  000 - 127 making it easy to assign and connect a midi controller. The manual does not tell you, and they don't know at Eventide customer service.
    • #121626
      badmelonfarmer
        sorry, not sure what you mean,  your post was truncated.
        Do you mean map the Midi CC values to specific functions? Or something else?
        Cheers
      • #121632
        I want the factors to show me for example midi program number 001 on the display, so all i have to do is match the number on the midi foot controller and not convert bank numbers to midi numbers with a conversion chart.
        And how do I change the display on the factors to do this? It can be done, I've seen the factors just display the midi numbers such as 001,002, 010, 100, 127, etc.
      • #132856
          Still unclear what you mean. Possibly you want a given MIDI Program Change number to load a specific 'Factor program. If this is the case, you need to set up a MIDI map, as described in the UM (p.38 for TF, p.34 for MF).
        • #132858
          badmelonfarmer
            not sure I have ever seen it on the display on the display other than, as Nick suggested, in the System/MidI/ProgramChangeMap. this is where you set the map for say PC004 to map to bank 7:2 or whatever you want, this is how I do it otherwise they are mapped from:-
            0 > 1:1
            1 > 1:2
            2 > 2:1
            3 > 2:2
            4 > 3:1
            etc
            ( I think it starts a 0, but it maybe 1)
