Dot9 pedal MIDI Channel setup issue
Home › Forums › Products › Stompboxes › Dot9 pedal MIDI Channel setup issue
    • #187168
      ghoi
        I have 2 Dot9 pedals; namely, Tricerachorus and Micropitch. The Tricerachorus is set at Channel 4 and Micropitch is at Channel 5. The reason behind this setup is that I want to have different preset number when I change program from my MeloAudio MIDI Commander via Ch 1 to my Boss GT-1000 CORE. The change of presets of other MIDI devices other than channel 1 will then be handled by GT1000CORE. This has been working perfectly with all devices at different MIDI channels (Boss SY-200@Ch2, TonexPedal@Ch3, Micropitch@ Ch4) before I bought the Tricerachorus recently.
        If I set both Tricera and Micropitch to the same MIDI channel, it will then work properly to change the presets on both pedals, but has to be the same preset number.
        If I set both pedals to different channels with different preset numbers, Tricerachorus will then fail to goto correct preset. The funny thing is when only one Dot9 pedal in the MIDI chain, it will work perfectly but Tricera will fail when I have 2 Dot9 pedals in the MIDI chain. But CC14 to turn on/off both pedal works. Other CC commands also work with different channel setup.
        Any idea when this is happening ?
      • #187173
          How is your MIDI chain configured? Are you using some sort of splitter box to connect to both dot9 pedals?
