August 21, 2011 at 8:42 pm #108069
I just got a DSP4000 second-hand and was a bit curious about a couple of things.
On the back, model no states H3000. Is this the same for all dsp4000s?
Also, mine came with a memory card, but it won't load, and claims 'battery is dead'. Any way to fix this? (I have no idea what is on the card, but if there's a cheap fix, it might be worth it).
August 21, 2011 at 9:02 pm #122564
Ekofisk:
Sorry, don't know. These are getting quite old now.
Ekofisk:
Depends what sort of card it is. The most common type are pink, with a rather ugly "brain" image on the label. If this is it, hold it with the label towards you, and the edge with lots of holes to the bottom. Then lightly press into the hole in the top of the right edge with a paperclip or something. While doing this, gently pull at the right-hand size of the top edge using your fingernail. This will free the battery and holder. This sounds fiddly, but you will understand in time. The battery is a BR2325 – a local Radio Shack or other electronics shop should have one. If not, try Mr.Google.
Other cards may have a tiny crosshead screw which holds in the battery compartment.
If the battery is dead there will be nothing on the card. These are hard to find nowadays, so probably worth risking a few fingernails to try and get it running.
August 21, 2011 at 9:17 pm #122565
Thanks for your very swift reply!
The card is indeed of the brain-type. I will have it up and running in no time!
October 9, 2011 at 7:58 pm #133885
did you fix it?
