Eclipse AES / EBU out as thru of my word clock
Home Forums Products Rackmount Eclipse AES / EBU out as thru of my word clock
    • #194138
      lukethemore
        Hi there,
        I’m setting up my devices with word clock: at the moment my RME UFX II is connected to the Eclipse with a AES / EBU Cable …
        My RME is the master, the Eclipse is the slave … everything is fine, the word clock is locked at 48 Khz.
        Now … what if I want to add a third device at my word clock ?
        Can I connect another AES / EBU Cable from the Eclipse to my new devices ? The OUT is working as a “THRU” ?
        Should I connect the third device with another cable (a different one / protocol) to my RME ?
        Thanks everybody !
      • #194167
        Puppeteer
          Yes, you should be able to daisy chain wordclock, though it is device dependent. Most devices support it though.
