Eventide H9, Background Noise, White noise, Hiss, Hum, In Front of Amp
Home › Forums › Products › Stompboxes › Eventide H9, Background Noise, White noise, Hiss, Hum, In Front of Amp
Viewing 0 reply threads
    • #115045
      thebluesman666
        I Know this topic have been discussed many times in the past but i would like to get a recent update on this issue.
        I currently have 2x H9 on my pedalboard, Eventide H9 pack awesome fx and i really enjoy them.
        I’ve noticed that the unit seems to be somewhat noisy when used in front on an amp with the fx engaged.
        I’ve ran a series of tests to try and Eliminate or Reduce the background noise.
        Bypass Mode :
        Using the Relay, (True Bypass) did help to reduce the background noise.
        Setting the input gain levels :
        Using this features did nothing to eliminate or reduce the background noise. I did get better results in audio quality of the used fx. The fx sound more presen with some gain added.
        Eventide support question :
        There you have it, to the best of your knowledge is there any other solutions of tests i could try out to acheive a better results ?
        Thanks for you time and help. yes
        Signal Chain — Guitar—- Pedalboard including the H9’s —- Guitar Amp
