EXP pedal is controling volume when H90 is off
Home › Forums › Products › Stompboxes › EXP pedal is controling volume when H90 is off
    • #188402
      Securb
        I’m running into an issue with my expression pedal on the H90: it’s controlling my overall volume, even when the unit isn’t on or engaged. It’s not acting like a typical volume pedal that goes from 0 to 100, but more like 40 to 100, and the tone gets noticeably darker and quieter when the pedal is heal down. I checked the global settings but couldn’t find anything to disable this behavior. Has anyone else experienced this, or have any insight on how to fix it?
      • #188403
          Can you please provide some more information? How is the pedal connected to the H90 and what parameters is the expression pedal programmed to control?
          How are you bypassing the pedal? Are you sure that the Program is fully bypassed by pressing the P footswitch in Select Mode?
