Home › Forums › Products › Vsig and Preset Development › Exponential DADSR free download.
Tagged: capacitor, envelope, Exponential, H9000, modelling, Spaghetti, vsig, white paper
- This topic has 2 replies, 1 voice, and was last updated 2 years, 10 months ago by
Puppeteer.
June 16, 2022 at 8:00 am #164088
Someone was chasing an exponential ADSR on a facebook group, so I foolishly decided to build one.
There’s probably a much more elegant way to do this, but here’s a proof of concept that does work.
https://godlike.com.au/index.php?id=420
Download the Exponential DADSR Proof of concept. There’s a bit of a manual. I haven’t implemented the fix for a potential glitch if you release before reaching the sustain section, but will have a go when I get a chance. If you build a better one, please upload and share.
July 3, 2022 at 12:00 pm #164293
I’ve implemented the capacitor modelling approach to DADSR as an alternative. It should be less processor intensive and a little more elegant than the previous attempt. I’ve also provided a white paper as to how I implemented this, that tells you which blocks to wire into if you wish to use this in your own VSIG creations (please read the white paper prior to using the VSIG code).
This provides a 5 stage (Delay, Attack, Decay, Sustain, Release) unipolar envelope with the output being updated at the sampling rate. The envelope modelling takes account of your chosen sampling rate. The capacitor model allows for easily expanding the envelope to implement additional stages, by creating step changes for each step, with the exponential curves being automatically calculated.
The white paper and the VSIG file is available at https://godlike.com.au/index.php?id=420
Any feedback would be appreciated. This is my first low level modelling done on VSIG.
April 30, 2023 at 8:59 am #170744
I’ve updated this (same link as before). I added a much more efficient implementation of capacitor modelling by utilizing the integrator block. This also provides a demonstration of how to use the integrator block effectively (because it is a tricky little thing).
