expression pedal
Home › Forums › Products › Stompboxes › expression pedal
    • #109011
      blackstuff_2
        hi everybody…i'm carlos from brail! sorry about my ignorance, as well i have an eventide time-factor…and i just underestand how to assign my new expression pedal vpjr 6181 from ernieball, i purchased it as indicates the time's factor manual…but i just can do that…i used the poedal as volume and it works…but my time factor seems not to recognize the ernieball…thanks !
      • #123714
        ndeshpande
          Hi Carlos,
          I believe we designed these pedals with the Ernie Ball VP Jr. in mind, so I'm a bit surprised that it isn't working. But no matter – I'll give it a go (we have TimeFactors and we should also have a VP Jr. somewhere…) and get back to you.
          Thanks,
          Nikhil
        • #123715
          ndeshpande
            Everything's working on our end… I just want to clarify how you're supposed to plug everything in (it's a common issue for most people during first time setup). There shouldn't be anything plugged into the input of the VP Jr. – it should just have its output plugged into the expression pedal jack of the TimeFactor. The cable can be balanced or unbalanced. Your incoming audio goes to Input 1 of the TimeFactor, and your audio out is going from the TimeFactor's Outputs. If this is how you've set everything up, then try initializing your TimeFactor (during power up, hold down the middle footswitch and the encoder; the encoder is the knob that you turn for different algorithms).
            Thanks,
            Nikhil
