Expression Pedal
Home Forums Products Stompboxes Expression Pedal
Viewing 3 reply threads
    • #169395
      joshuacwhalen
        My expression pedal is controlling volume somewhere and I can’t figure it out. No matter what I map to the expression pedal it’s always controlling volume like a swell. I’m using a Mission Engineering EXP Pedal. I can’t seem to find where it’s linked to. This is my first time plugging in an EXP pedal. Thanks for the help!
      • #169396
        joecozzi
          Does this happen for every Program? If so, the expression pedal could be mapped to the global “P In Gain” parameter. Check Global – Pedal Ctl to see if the expression pedal is mapped to anything.
          • Press PROGRAMS & ROUTING until you enter the System Menu.
          • Select Global and navigate to the third page of controls.
          • Once you’re in Global – Pedal Ctl, use the first quick knob to scroll through all the mappable parameters ensuring nothing is mapped to the expression pedal on the input you connected to.
        • #169400
            joshuacwhalen, is this using an H90, or an H9 / ‘Factor?  Joe Cozzi has you covered on the 1st one.  It might be another procedure with an H9.
          • #169401
            joshuacwhalen
              That was it thanks! I was looking in the wrong places. 😓 I wonder if this is mapped from factory or if I did it somehow by accident! Again thanks for the help!
