Expression Pedal Inversion with Y cable
Home Forums Products Stompboxes Expression Pedal Inversion with Y cable
    • #142179
        Very mysterious. I would suspect your Y-lead. Try using the one we recommend.
        https://www.eventideaudio.com/support/downloads/using-both-aux-switch-and-expression-pedal-h9
        Moog does not give any info on this pedal, so it may (or may not) have strange wiring.
        • #142180
          gkellum
            I don't think that's the problem. We tested the Moog pedal when we were putting together this document about using an H9 with an expression pedal and aux switch:
            We saw the same thing.  If you want to use an expression pedal and aux switch, you really should use one of the expression pedals that we recommended in that document and know work.  A lot of the expression pedals we tested didn't work in this configuration.
          • #142183
            JES
              Glad to have confirmation of the behavior.  And thanks for the suggestion.  Maybe I will switch up, or just live with it for now.
              gkellum wrote:
              I don’t think that’s the problem. We tested the Moog pedal when we were putting together this document about using an H9 with an expression pedal and aux switch:
              We saw the same thing.  If you want to use an expression pedal and aux switch, you really should use one of the expression pedals that we recommended in that document and know work.  A lot of the expression pedals we tested didn’t work in this configuration.
          • #113170
            JES
              My Moog EP3 works fine via the expression pedal input.  Today, I tried to switch to a Y-cable setup so that I could also use a switch, but now values are inverted (heel=100, toe=0),  Interestingly, if I reverse polarity on the pedal, which is easy to do, I get the same read out, so auto-calibrate is working but somehow in reverse.
              Thanks for any help you can offer.
