Home › Forums › Products › Stompboxes › Expression pedal working then not working
October 12, 2015 at 6:15 pm #112934
H9, brand new. Using Roland EV 5 pedal. Worked for about a week, then stopped working. (On a gig, no less.) I’ve re-istalled the latest firmware update, checked the EV 5 with another Factor pedal and its working. Do I have to send this puppy back? Pleas say it isn’t so.
October 12, 2015 at 6:44 pm #141001
Hard to know without having it in front of me, but a few things to try:
1) The pedal has a calibration knob (maybe called Minimum Volume) – try adjusting this and see if it makes a difference.
2) The H9 has various settings related to pedals. Try setting EXPTIP to PEDAL.
3) Try the pedal calibration (PDLCAL = ON)
4) Try wiggling the jack in and out in case the contacts are dirty.
Quite likely that one of the above will produce a result …
October 12, 2015 at 8:07 pm #141002
So none of the above worked,. When I plug the pedal in and change or activate a patch, the display jump all over the place with random numbers. I think I’m going to have to send it back to Eventide. I don’t know what else to do here.
October 12, 2015 at 8:08 pm #141003
Not sure where this is done.
BTW, I found this. Still same problem. Almost like there is an LFO at work somewhere here.
Is that possible?
Look in the latest (online) UM . It's in the System menu.
We have had very few problems with the pedal input, so my guess is that it is something at your end. But, if you are sure that this is not the case, you should send it in.
October 12, 2015 at 8:17 pm #141004
Looks like the parameters are going from min to mak on the H9, though I’m not moving the pedal.
October 13, 2015 at 4:34 pm #141028
Found the EXPTIP to PEDAL in the UYIL menu, (Says EXPR now.)
I’m guessing you’re correct in rthat the problem is on this end. (the jockey not the horse)
Gonna get a hold of the Ernie Ball 25k volume pedal and give it a shot.
