Home › Forums › Products › Stompboxes › External Control Access to H90 Perform Mode 2 Please
- This topic has 8 replies, 4 voices, and was last updated 4 months, 1 week ago by
h90rus.
February 7, 2023 at 4:15 pm #168936
Small thing please. I have the play modes assigned to a 3 way footswitch. I can get to Perform Mode as expected via a switch. I was hoping that when I press the switch again it would toggle to Perform Mode 2 (and back) – like on the unit. Can this be changed please?
An even smaller thing. In H90 Control, it took me ages to find the Program Bypass switch – mainly because it wasn’t near where I expected it to be. The lower right also requires quite a cursor movement. Can we have it somewhere more obvious and more convenient please?
I have done a bit of UX work so I hope these are well received as the unit is brilliant, and for what is packed in there a UX masterpiece – especially when the customisation is used.
February 7, 2023 at 5:03 pm #168943
HI rograt,
I have the play modes assigned to a 3 way footswitch…I was hoping that when I press the switch again it would toggle to Perform Mode 2 (and back) – like on the unit.
I understand what you are asking for and I can relay the message to the team. I can see how this same button function would be useful. That being said, on the H90, successively pressing any of the mode buttons, Select or Perform, does not return to the previous mode. Rather, you must press each specific knob/button to get into the mode you want. You say these same modes are mapped to a 3-button footswitch. Wouldn’t pressing the correct mode button work the same way for you?
Noted.We thank you for your feedback.
February 10, 2023 at 8:20 am #169020
Thanks joecozzi for your excellent follow up as usual.
I am not sure I am understanding your workaround so I’ll just give an example. On most factory programs if I go into Perform mode I get a bypass toggle on the 3 main switches. If I click on the Perform knob again I get momentary bypass options. If I click on the knob again I go back to the toggle bypass options. I want to reprogram those 6 options but I can only access 3 via my external 3 way switch. I could stomp on the Perform knob but I fear one day I will have an accident.
Thanks
February 10, 2023 at 9:31 am #169023
I think I understand the source of the confusion. I was thrown off because originally you had mentioned “Play modes.” Eventide considers the play modes to be Select, Perform, and Bank; I thought you wanted to switch between those, but what you want is a way to toggle the Perform mode functions from an aux switch, correct?
Whenever we enter the Perform mode, we have six performance controls across two pages. You could have three on the H90 itself (1,2, and 3) and assign the other three to the aux switch (4,5,6). In System settings, in the Global-Pdl Ctl list, you have options titled PERFORM 1, PERFORM 2, PERFORM 3, PERFORM 4, PERFORM 5, & PERFORM 6. You can assign these to any aux switch number you want. Doing so will allow you to access the performance functions without even needing to go into Perform mode. In fact, you could have two 3-button aux switches connected to H90 and always have all six perform functions available; you could even use MIDI. The great thing about using the “PERFORM” mappings I just mentioned, is that the actual functions for every Program can be different but your aux switches will always just point to the button positions in Perform mode.
February 10, 2023 at 11:31 am #169024
Yes that is correct. Apologies for throwing you off the trail. Access to those 6 modes is exactly what I want and as you say it will be different for every program.
The advantage of switching between pages on the unit is that the display tells you exactly what you are switching so if I could do this with my remote switch it would be a lot cleaner.
If I had a second bank of switches I would have to sacrifice the EXP pedal which is like my right arm. Unfortunately I’m now maxed out on control in’s on the ES8 or I could have put the EXP into the ES8 and relayed MIDI out.
So, yes if the remote switch could toggle banks rather than just go into Perform mode it would be better.
February 10, 2023 at 11:39 am #169025
You meant toggle Perform mode pages, right? I ask because toggling between banks is mappable to an aux switch.
February 10, 2023 at 12:04 pm #169028
Exactly. A reminder of my setup.
So left double footswitch does bank up or bank down and right footswitch does program up or down (with this I can immediately change for example from Whammy +1 Oct to Whammy -1 Oct). Also bypassing the presets is on 7&8 of the Boss ES8. The whole set up has a nice tactile console feel to it but I don’t really want to add anymore switches 🙂
Ignore the bottom footswitch – that’s for the Marshall
May 11, 2026 at 11:48 am #195412
Id like to get some help on hooking up strymon multi 3 button footswitch to h90… so far noting works and ive tried 2 different trs cables that both work on other gear
May 11, 2026 at 11:56 am #195413
Can’t speak specifically for the wiring of the Strymon 3 button, but the h90 should work fine with a normally open switches connecting:
tip to sleeve
ring to sleeve
tip and ring to sleeve
assuming the Strymon does this, I would confirm you’ve correctly configured the exp port as a 3 button switch and not an expression pedal per:
https://cdn.eventideaudio.com/manuals/h90/1.12.5/content/system-menu/io.html
