FactorLib Doesnt Work with V3 Update
Home › Forums › Products › Stompboxes › FactorLib Doesnt Work with V3 Update
    • #108013
      dave b
        I recently updated to the version 3 software; as well as the latest Update Utility and FactorLib software. I'm using an M-Audio Uno Midi interface to connect to the Timefactor Midi In/Out.
        When I open FactorLib I set the Config to the Uno usb in/out but when I try to "Open From Midi" I always get a "Check Cables and Config" message. It will not read the presets for my Timefactor.
        I have done a reboot to get the computer to recognise the Uno hardware, plugged and re-plugged in the cables and have done a reinstall of all Eventide software as well.
        Nothing seems to make a difference. One other thing…When I open the Factorlib software in the bottom right corner of the screen I see a message that says WAIT and next to that a numerical seconds count. I have left the pedal plugged in for over an hour just in case it needed more time to make a connection but it made no difference.
        I'd really appriciate some guidance in this matter…
        Thanks,
        David Burns
      • #122450
          Sounds like a MIDI hardware problem. Try using the USB.
        • #122451
          dave b
            That was it…
            I didn't realise you could simply use a USB cable. With the first FactorLib version it would only work with a MIDI interface…
            Thanks for the help…. I like the New FactorLib so far….
            Dave B
