Feature Req – Harmadillo Stereo Panning
Home › Forums › Products › Stompboxes › Feature Req – Harmadillo Stereo Panning
    • #206357
      scottohelia
        Hi there,
        I’ve recently upgraded from the GFI Synesthesia to the H90; i am a very happy customer but was wondering about one feature that i’m missing in the Harmadillo algorithm (may well be user error). On the GFI Synesthesia Harmonic Trem algorithm you could set the mode to stereo, and the lows and highs would pan opposite to each other to create some great movement – you couldn’t really do any deep editing to create a stronger/more subtle stereo field (or width) but it was a great stereo option.
        I don’t feel like i’ve been able to get any sort of panning features out of the Harmadillo algorithm, so I was wondering if i’m missing something, and if not whether it would be possible to add any width or stereo field panning parameter into the algorithm?
        Thanks so much in advance
      • #206360
        charlespirrello
          My understanding is that the H90 using that Harmadillo algorithm does not pan side to side, there are probably other algorithms you could use with that to get some of that effect(?)
        • #206372
          scottohelia
            That’s what I had figured, it would be a great feature to add – I was able to approximate it by putting the tremolo pan after, but it definitely wasn’t perfect
