Feature Request: H90 Insert Act/Byp (M)
Home › Forums › Products › Stompboxes › Feature Request: H90 Insert Act/Byp (M)
    • #177209
      jmay214
        I’ve ran into a situation where I need I need a dedicated midi command to toggle on an Insert and a 2nd one to toggle it off. Not the only available option which is activate and bypass being tied together (CC value 64-127  for both on and off).
        A midi command like the Momentary Preset On/Off would solve my problem (CC value 0-63  bypass/ 64-127 activate). Are there any plans to implement this? If not please consider such a simple request.
        For the record, this isn’t an issue where I’m needing momentary switching. I have a midi controller where I can program separate midi commands for a press and a 2nd for release of a button. It’s for switching between 2 delay presets (one on h90 and other is Volante in insert loop) and I’m needing changes to the insert state in a specific way that I can’t find any usable workaround.
      • #177220
          Thanks for the thorough feature request, this is something we’ve discussed adding. Sorry, I can’t recommend any workarounds for you to use. Thanks for your patience.
