Garbled sound when changing presets while synched to MIDI clock
Home › Forums › Products › Stompboxes › Garbled sound when changing presets while synched to MIDI clock
    • #114190
      aviavi
        Hi. I don’t know if this is a bug or what, but when my H9 is synched to Ableton Live’s or Logic’s MIDI clock  and I change presets, the sound of presets that follow tempo (like Harpeggiator) are completely garbled.  There is no other MIDI command being sent, just preset change.  I’ve tried this with a Babyface Pro and iConnect MIDI 1 midi connections.
        If I stop Ableton/Logic, wait a couple of seconds, and restart, the H9 is synched and the preset is not garbled.  I’ve tried Enabling and DIsabling the MIDI Clock Filter, and this doesn’t help.  It also doesn’t matter if the preset change is done manually (directly from the H9) or via a command from within Ableton.  (Things are ok if I disable H9’s MIDI input clock, but this defeats the purpose of having everything synched.
        Any advice?
      • #146496
        aviavi
          Oh, duh, I had Global tempo off.  Turning it on solved the synch issues.
