getting bad sav with the beta firmware
Home Forums Products Stompboxes getting bad sav with the beta firmware
Viewing 5 reply threads
    • #106592
      jzucker
      Is that a known issue?
    • #119383
      Sav ?
      Full details please – what did you do, what happened, what should have happened ? Etc.
    • #119386
      jzucker
      saved a patch to a bank, got "bad sav" in the LCD status. It's pretty obvious what should have happened.
      Patch was a vintage delay, xbits=12
    • #130501
      That helps. It's very hard/impossible to diagnose the problems with minimal information – the more the better.
      This message could come from either a hardware or software problem. We have no reports of this as a software problem with the beta release so a hardware issue is more likely.
      You don't say how many times this happened, so it may have been a glitch or a real problem. Try copying any saved presets you need to keep somewhere safe (FactorLib ?), and then doing a "Restore Factory Effects Presets and System Settings" as described on p.41 of the TF User Manual.
      If you still get this problem, the unit needs to be looked at.
    • #130502
      jzucker
      no, not a hardware problem. No problems with the 2.x rev of the firmware.
    • #130503
      The latest version of the software saves presets in a different place which has not been used before.
      You should probably go back to the previous version and stay there.
