Home › Forums › Products › Stompboxes › good midi pedal controller for timefactor (and later pitchfactor)
February 4, 2009 at 10:45 am #106051
Hi everyone,
I'm new here and this is my first post so hello!
I've ordered a timefactor pedal and i want to put the TF on top of my amp and use it in the fx-loop of my amp.
To control the TF I need a (not to big) midi footcontroller on my pedalboard.
a controler with expression pedal or with an input for one. (to control TF parameters in realtime
)It should also be able to controle the TF in bank mode and play mode. (at least for tap tempo)
And last but not least, it should later on be able to control the pitchfactor at the same time too. (in bank and play mode)
Any suggestions?
Or do I just want to much from a controller?
Thank you for your answers and sorry for the lousy english.
greetings from Belgium
February 4, 2009 at 10:10 pm #118247
Hi
I currently use a Ernie Ball Mono Volume pedal ( 6166 ) as an expression pedal to control my TF. And as Aux Switch, the small Digitech FS3.
Hope this will help 🙂
cheers
February 4, 2009 at 11:16 pm #118248
sathy.ngouane:
Hi sathy.ngouane,
thanks for your reply.
Yeah I know about the ernie ball and the FS3 but that will take two cables running from the peadlboard to the TF at my amp. I asume you haveyour TF on your amp instead of your pedalboard?
via midi that would be one cable therefore my question.
Maybe I'm making a big deal out of nothing.
Do you use the FS3 to change patches? If so what do you do to tap tempo?
(or go a bank down instead of only going up)
Thanks again.
Jesse
