GTR 4000 Confused….. help!
Home Forums Products Rackmount GTR 4000 Confused….. help!
    • #114131
      Hello eventide.
      I’m not sure if they eventide is having a problem or my brain is, but if an effect is set with an mono input
      and a stereo out, should’nt I be getting both meters going on the evetide thus getting a balanced stereo signal
      when using a guitar, other wise I have the left with wet and dry and the right completely wet.
      Am I having a firmware problem or is this how it works?
    • #146249
        Some effects are designed for mono inputs, while others expect stereo or dual mono. If you give a stereo effect a mono signal, it will not automatically route the input to both channels, and the result will be as you describe.
        If you always use the unit this way, I would suggest a Y-lead.
