H8000 won’t start
Home › Forums › Products › Rackmount › H8000 won’t start
    • #109560
      Hi, out of the blue my H8000 won't start up. It gets to the end  and then reads "problems with setup". I restarted a few times but get the same message. I ran a test but it's taking more than 24 hours and it's still running…???
      What can I do to get it working normal again. I believe I'm still in the 5.1 vv software.
      Thanks.
      Marcel
    • #124254
        Probably after the "problem with setup" message, it will invite you to press another key for more info. You should do this.
        Either way, the first thing to try is a CLEAR SETUP, followed if necessary by a CLEAR INTERNAL. See UM for info.
