H8000FW lost presets
Home › Forums › Products › Rackmount › H8000FW lost presets
    • #107964
      Hello.
      i have a small problem with my h8000fw. Few days ago i realized after reading manual that i don't have some preset (for example spectrum analyzer). i have this manual in paper form from original package. Can someone tell me what's going on? maybe i should change some options to get to those presets but in "criteria" i have every type of preset active.
      thank you in advance!
    • #122334
        It may well be your criteria settings. You could try a "clear setup" to be sure that everything is visible.
        Also, look to see if there are any ranges of numbers missing, not just individual presets. This is unlikely, but could indicate a memory problem. Check also for errors at startup.
      • #122339
        Thank you. i'll try to clear everything tomorrow. i hope it's only this. maybe i should make an upgrade and see system reaction.
