H9 – activate tuner w/ switch while using exp pedal
Home › Forums › Products › Stompboxes › H9 – activate tuner w/ switch while using exp pedal
    • #114249
      What is my best option to activate the H9’s tuner function other than pressing both switches simulatneously (which i hate)?  I use an expression pedal so is my only other option midi?
    • #146749
      gkellum
        It's possible to use an expression pedal and a one button aux switch at the same time. This page describes how to do that:
        https://www.eventideaudio.com/support/downloads/using-both-aux-switch-and-expression-pedal-h9
        Keep in mind though that this might not work with the expression pedal you already own; in our testing we found a great deal of variability in how different expression pedals work. So, if you consider that you might have to buy a new expression pedal and an aux switch to do this, it might make more sense financially to buy a MIDI pedal.
