Home › Forums › Products › Stompboxes › H9 and receiving multiple midi messages
May 1, 2016 at 3:51 pm #113432
Afternoon All,I’m pretty new to midi an midi mapping etc… I am usinga voodoo labs ground control pro…along with the H9 core (with a few extra purchased algorithms). My question is this… Is it possible to recall a speciic preset via midi from the H9 with the GCP AND also bypass the H9. If so,how do i set that up? What I am ultimatey trying to accomplish would be to have a preset on the GCP that included say one of the harmonizers on the H9 active when I select that preset, then have a way to bypass the H9 for parts of the song I don’t want the harmonizer on for, like the solo, and then when I go back to the chorus, have it activated again. I have the H9 sitting in my rack with my other effects, so A) cannot manually bypass and B) even if I could, sometimes there are other effects Iam turning on and off at the same time. Is this possible? and if so how do I configure that? Thanks!
May 1, 2016 at 8:10 pm #143256
Assuming I understand:
If you save a program when bypassed, and then load it from a MIDI Program Change, it will load bypassed. Hope this is what you need.
bypassed. Hope this is what you need.Yes! Ultimately what I need… How do I save it bypassed?
Make sure the unit is bypassed (active light off), then save the preset.
