Home › Forums › Products › Stompboxes › H9 AUX SWITCHES V4.8.0
July 11, 2014 at 8:18 pm #111781
HI,
JUST UPDATED S/W BUT I AM USING THE 3 AUX FOR TAP UP/DOWN.
THE PREVIOUS VERSION HAD AUTOLOAD OF PRESET THIS NOW REQUIRES TO HIT THE ACTIVE BUTTON.iS THERE NOW AN OPTION FOR THIS?ANY RELEASE NOTES FOR THE LATEST S/W?
MANY THANKS
July 11, 2014 at 8:34 pm #126320
Yes, the behavior of the Aux switch changed from 4.5.0[4] release to the current release. Here’s the story:
In the 4.4.6[0] and 4.4.6[1] bams, the increment and decrement preset functions that can be assigned to aux switches or MIDI cc messages would increment and decrement presets but leave them in a pending state. In 4.5.0[4], the increment and decrement preset functions would increment and decrement presets and activate them, but this wasn't actually an intentional change and it made some users happy while upsetting others. So, in 4.8.0[1] we went back to these functions incrementing and decrementing presets and leaving them in a pending state, and we added a new function named in the app "Left Footswitch (aka Active Footswitch)" that can be assigned to an aux switch or MIDI CC and used to activate a preset.
We have agreed amongst ourselves on adding two new functions Load Next and Load Previous in the next release, i.e. the Looper release, which will increment and decrement presets and activate them. This means users will be able to choose in the next release whether incrementing and decrementing from an aux switch or MIDI CC will activate the preset or not. Ideally, we would have added those functions in the current release 4.8.0[1], but there just wasn't enough time.
July 11, 2014 at 9:18 pm #126322
hi
thanks for the swift reply.
ok great you know my next question then………!
this was working perfectly for me as the unit sits on the amp and I control it via a small midi controller and the switch box.
also noted midi is disabled when the usb connector is in.
one final thing, are there any plans for some more multi patches ie delay/reverb.flange delay?
again thanks for your time.
July 11, 2014 at 9:36 pm #136997
paul johnson:
You may just want to go back to the 4.5.0.4 version of the H9 software until the next H9 release. Given how your stuff is set-up, it sounds like it's going to be inconvenient for you not to have the preset up and preset down functions load the preset automatically.
paul johnson:
Yes. There are some plans for more multi patches. What's difficult though is that no one is asking for the same combinations. 😉 -
July 12, 2014 at 8:52 am #136998
Great thanks,
just one thing if I go back to the 4.5.0 will I be able to recover the eq patch when I reload the new version later?
cheers
July 12, 2014 at 11:20 am #136999
paul johnson:
Yes, you won't lose EQ Compressor by doing that.
