H9 Bluetooth
Home › Forums › Products › Stompboxes › H9 Bluetooth
    • #110991
      Has anyone been able to pair their H9 with either an iphone or iPad? I am unsuccessful on both. As well there is no H9 listed in the registration dropdown menu on the Eventide site to register. Any help is appreciated.
    • #124598
      gkellum
        Where exactly in the pairing process are you getting stuck? Here is a help video we made that walks you through the pairing process:
        Basically, if you go into your Bluetooth settings, you should see the H9 appear there with its serial number as its name.  When you select it, it will ask you for its PIN.  The last four digits of its serial number are the default PIN.  You can change both the name and the PIN in the stompbox's setting screen though.
