H9 Blutooth PIN lost
Home Forums Products Stompboxes H9 Blutooth PIN lost
Viewing 3 reply threads
    • #163401
      docmidnite
        Hey guys,
        I forgot my H9 Blutooth PIN to get access. How can I fix that?
      • #163402
        joecozzi
          Hi docmidnite, if you assigned yourself a custom PIN, you may need to contact support@eventide.come for assistance.
          If you did not assign yourself a custom PIN, then the default PIN is the last four digits of the serial number of the pedal, which you can find on the bottom of the pedal itself, or it appears in the Bluetooth pairing list on any mobile device or computer. You can also find the serial number in the pedal’s System Settings.
        • #163403
          DauntonHH
            It’s the last four digits of the serial number.
            that is on the underside of the H9 or it can be viewed in your profile on the Eventide site.
          • #163424
            docmidnite
              Hi docmidnite, if you assigned yourself a custom PIN, you may need to contact support@eventide.come for assistance. If you did not assign yourself a custom PIN, then the default PIN is the last four digits of the serial number of the pedal, which you can find on the bottom of the pedal itself, or it appears in the Bluetooth pairing list on any mobile device or computer. You can also find the serial number in the pedal’s System Settings.
              Wow, thank you guys!
              I tried all the digits, me stupid.
              I can´t remember a change so I guess it´s the last 4 digits!
              Thanks again!
