H9 channel 1 in front of amp and channel 2 in effects loop using a loop switcher?
Home Forums Products Stompboxes H9 channel 1 in front of amp and channel 2 in effects loop using a loop switcher?
Viewing 0 reply threads
    • #111360
      mendel
      As some of the algorithms are better in front of the amp / distortion and others after that in the amp's effects loop, has anyone tried running the H9's two channels separately in front of the amp and in the fx loop using a programmable looper so only one of the H9's channels is receiving and engaged at the time? Both a Voodoolab GCX and RJM effects gizmo could handle the switching.
      Can this work or are there issues with the H9 preventing this or to watch out for. Additional ground loops maybe?
      Thanks
