H9 Control Crashes after update
Home Forums Products Stompboxes H9 Control Crashes after update
Viewing 5 reply threads
    • #115047
      digbob
        just updated to the newest version of H9 Control,
        now the software try to start and then copletely crashes, i see the window for a very short time and then it crashes and after thatz i got
        the message h9 control suddenly ended from my mac, it dont work anymore
        it crashes when trying to open the algorythms tab
        when im fast enough to hit another tab it opens, as soon as i try to hit the algorythmn Tab
        it crashes
        the H9 is on the latest uodate
        please advice what to do, before this update all was fine
        is it possible to downgrade to the former version ?
        im 0n Mac OSX 10.13.6 Macbook Pro 2016
        i attached  the report which was created from the mac after the crash
      • #150536
        gkellum
          Ok, thank you for sending us that crash report.  I just sent you an email with a link to a new build which hopefully will fix the problem.
        • #150546
          It is also crashing on me when I try to open after update.
          • #150547
            gkellum
              Alright we should have a new build posted soon with a fix to the problem.  There is a work around you can use though.  As soon as the app launches but before it crashes click on the Settings button in the app's bottom menu bar, go to 'Algorithm Sorting', and and select any sorting type except 'By Name'.
              I'll post back to this thread when the new builds are available.
          • #150549
            paulmarshall
              I’m having the crash too. I’m on Mac OSX Mojave and attach the crash report. The workaround of clicking settings is not working for me. There’s no way out of the loop.
            • #150551
              davebrubaker
                When exactly do you expect a working version? I’m running Mac OS 10.13.6
                Where can I download the previous working version of H9 Control? Right now I’ve got nothing.
                I have to say that I’m really dissapointed. I’m a dedicated customer (3 h9s) and I understand that software development can be a complex process. BUT… it would be appropriate to place a warning on the download page AND a link to the previous working version of H9 control. It would have saved us some aggrivation.
                Thanks for your help.
                • #151651
                  Found that the H9  Pedal just needed to load the software and the Pedal  display was cyclying thro UPDATE : WRITE : ERASE I left the pedal for a few minutes and it all came good, I hope this helps other people who come up against this error, Don’t Panic just let it update the software within the Pedal in its own time.
              • #150555
                gkellum
                  Here is the new release that should be posted on Monday.  Could you please give it a try?  It should fix the issue you're having:
                  https://s3.amazonaws.com/com.eventide.downloads/Installation+Files/Installation+Files+Stompboxes/H9Control-3.5.2-osx-installer.dmg
